app.tapp 1.1.1
RchGrav
Jun 8, 2007
242
when will this be avilable on 1.1.1?
It is available....
#1 Downgrade to 1.02 & Install AppTap
#2 Get Conceited Softwares Beta Sources for AppTap
#3 Install Symlink Hack (on apptap) and the UPGRADE to 1.1.1
#4 Use iphuc to Jailbreak 1.1.1
#5 Install SSH
#6 Manually copy in installer.app
#7 get the beta sources again and install tripz2pogo to enable the springboard to show apptap
These are the steps to properly jailbreak 1.1.1, they are overly simplified and coming from my head, but this is what I did to get it working..
Hopefully seeing this broken down into simple steps will help some in doing the deed. I personally like the "beta" tutorial at iPhonealley as it seems easier to follow and even more correct (to me) than the official instructions.
The final release of the iphuc jailbreak works quicker and is a more direct method of patching fstab on 1.1.1 iPhone to achieve the jailbreak.
You know you are close to jailbreak when you plug in your 1.02 iPhone to upgrade to 1.1.1 and the iPhone shows only 300mb free due to the symlink hack. Upgrade, Jailbreak, Install Apptap.. yay!
Good luck all!
Best,
Rich
mikeKICKz
Jun 28, 2007
33
SAN DIEGO
Nobody knows for sure when they will release a version for 1.1.1
I would just stick with 1.0.2 until 1.1.1 modding gets smoother.
619 in the house
yeah i think i will wait till the site i downloaded installer from updates this process. i have no idea how to use ssh. i would like to learn.
SIX ONE NINA
