App Tapp installer error (I'm with 1.1.3)
todesto
Sep 30, 2007
59
Hi, All. :)
Sorry if this question has been addressed before, but I couldn't find the answer.
I am with 1.1.3 jailbroken with ziPhone....
I had installer working fine, but after tweaking some to get callD to work (following the instruction by TinMan, thanks tinman by the way;)), I must have done something as I don't see the apps installed in uninstall category.
for example, I have converter, interval, garf installed, but it doesn't show on uninstall category. In order for me to uninstall, I have to reinstall to show it, then uninstall.
Anyway, my problem is when I try to refresh the source, it will run for a while, the it exits out back to home screen....:oops:
Any suggestion for fix is appreciated.
Thank you in advance.
