App.Tapp (PC) not working with iTunes 7.4.1.2 and 1.0.2 firmware?
Rainmaker
Sep 9, 2007
11
As a newb iPhone modder (but an experienced phone modder), I have been unable to install app.tapp to my new phone (purchased a day ago) with the 7.4.1.2 iTunes, and a 1.0.2 firmware. This is after carefuly following the (admittedly idiot proof) instructions for windowsXP, and trying variations thereof.
Obviously, I could still be making a mistake, so my question isn't so much "what am i doing wrong", but rather; Has anyone been able to successfuly install App.tapp with a newish iPhone, new iTunes, and windows user?
Any heads up either way would be appreciated. I can't help but think I'm missing something.
~Rain
If you are interested as to what problems I am having, ask, and I'll explain what I am experiencing.
redstar299
103
Most of the mods are for iTunes 7.3 at this point - downgrade he iTunes to an older version. I think the only major difference of 7.4 is that with the iPhone you can download over wifi from the iTunes store. Its nice but not that important
Jun 19, 2007
22
Okay, My friend has bought a iPhone recently, And I did use app.tapp with a 1.02 firmware and 7.4 iTunes. Are you sure that iTunes is closed when using app.tapp?
redstar299
103
iTunes is not closed using apptap. It is iTunes 7.4 which locks up the phone. I use apptap, ifuntastic and iTunes 7.3 and everything works fine.
TomTomTuning
Aug 10, 2007
196
Camp Hill, PA
I have all the latest versions of iTunes and firmware of my phone. And i have AppTap (Installer)
Make sure all your iTune processes are shut off when trying to do this.
Rainmaker
Sep 9, 2007
11
Thanks for replies
Ok fellas thanks for the replies.
I'll give it another go around by first closing all the processes via task manager (not just iTunes).
Thanks again.
Rainmaker
Sep 9, 2007
11
Still no luck
I swear i'm not an idiot (we'll see) but I still can't get apptapp on. Here's what i've tried.
1. Downloaded apptapp 9.1
2. Plugged in phone.
3. Closed iTunes.
4. Ran Apptapp.
* Prog. freezes at dos prompt (iPhonecom) phase, last message is "Found iPhone"; the message before that is something like, "Stage 1.2 putting in restore mode".
I've also tried going into my task manager, ending following processes, iTuneshelper.exe, and Ipodservice.exe (there is also an Applemobiledeviceservice.exe, but if you don't leave it running, apptapp can't find your iPhone)
So,
1. Ended all Apple processes.
2. Ran Apptapp.
* Prog. freezes at same point (see above).
I'm stubborn, and don't plan on quiting trying, all though my poor phone has been through more "Restorations" than the Sistine Chapel.
Any help would be appreciated.
~RM
EDIT: Someone asked me if I have ever moded my processes via service.msc.. I have. Evidently, that screws my install. Going to try install at office. Sure enough, now it's working.
ajoiner
Sep 18, 2007
I have a newer 8G with iBrickr, Installer, etc. running on 7.4.1.2 and 1.02 with no problems.
I am using 9.0 for AppTappInstaller though...
Exit iTunes, and then CTRl+ALT+DEL and exit iTunesHelper.exe
After you've done that, run your installer. It should work fine...
the watcher
Jul 5, 2007
183
app tapp problems
i download and install app tapp to my iPhone, but the one game app i wanted to play which is nes emulater is not working do anyone els have this problem and how do u fix. my iTunes is firmware 7.4.2 ihad no problem installing it but nes emnlater dose not work help. it say cannot find rom
redstar299
103
You have to put the roms in there yourself..did you think the NES Emulator came with every single game? You need to choose the games you want and load them manually.
http://www.theoldcomputer.com/Libarary's/Emulation/NES/ROMs/NES_roms_summary.htm
Download the roms of the games and use either ibricker if you use a pc or ifuntastic on a mac to drop the roms into:
var/root/media/RO Ms/NES/
Then when you open NES Emulator on the iPhone it will play
the watcher
Jul 5, 2007
183
how do i ad rom using ifuntastic, i am new to the mac world
edgar
Sep 20, 2007
guys im confused i use windows, after seeen the hacks on youtube i tryed it now my fone dosnt work all it says its please connect to iTunes, if any of u have any idea what i can do pleas give me an answer, at Crazyara818@yahoo.com tnx
mikeKICKz
Jun 28, 2007
33
SAN DIEGO
i'm also having a problem. i got 7.4.1.2 and got it onto the phone but cant dl any ore than 3 widgets which means i cant scroll the homescreen. anybody have any idea what's going on?
edgar
Sep 20, 2007
okey guys i fixed the problem i have a lot stuff on it, i need help with one more thing how do i make my screen to scroll up or down, please answer me if u no
bizzy045
Jun 27, 2007
93
you need to install the summerboard app from the installer...then also restart your phone after installation by holding the home key and sleep/wake key down for about 5 secs till the Apple logo appears...
joeboo24
Oct 11, 2007
3. Closed iTunes.
4. Ran Apptapp.
So,
2. Ran Apptapp.
~RM
Hey Rainmaker,
I'm having the same problem. Were you able to modify your iPhone?
joeboo24
Oct 11, 2007
app. tapp not working with iTunes 7.4.1.2 and 1.0.2 firmware
Hey Rainmaker!
I'm having the same problems.
Were you able to install the apps in your iPhone?
Rainmaker
Sep 9, 2007
11
my personal problem was...
The fix for me was to use a different computer. I had changed my "services" or my startup "process" to streamline my system and free up some system resources. But, by doing that, i screwed up something with itunes-usb.... whatever.
So, if you have fiddled with your services or processes on your computer, either default them, or install app tapp on a different pc.
Other than that, I'm without knowledge.
~RM
