App that allows quick access to audio control settings?
thetinman101
May 26, 2010
Greetings all. I am looking for a particular app. I was in the FutureShop the other day and someone had loaded an app onto the stores demo iPad. The app was a quick shortcut into the settings menu. It was a floating dot (target) on the right hand side of the screen. When you touched it, it brought out a menu that would allow you instant access to audio controls, control panel settings and I think that there was another menu that I don't recall right now. Because it was a store demo unit, I am fairly certain the iPad was not jailbroken, so this app must be in the app store.
Any help would sure be appreciated here. I have the iPad 2 on iOS 5.0.1 and it is JBed.
Thanks in Advance for your help.
OneGoodApp
Apr 29, 2012
Not sure if this is what you are looking for, but check it out:
1. In the Settings, tap General,
2. scroll all the way up till you see Accessibility
3. tap on Accessibility, scroll all the way up till you see AssistiveTouch
4. turn it on
You should be able to see the dot, aka AssistiveTouch
HTH
