Apple has this cassette tape adapter...
theraker007
Jun 15, 2007
322
it says.. supports iPhone on it.. nothign else in their store does. Do you guys think this cassette tape is just as viable as the other options out there, seeing as they are not many?
theraker007
Jun 15, 2007
322
just bought this. Works great for Udio and u can listen to video through car speakers as well
Martlet
Jul 11, 2007
145
See other ipod to car audio sites for more in-depth info on potential solutions for your specific situation.
Basically, the cassette tape adapter is the second lowest common method of getting audio from a headphone jack to a cassette deck equipped stereo that has no other inputs. The only thing worse is (most) FM transmitters.
Two great things about it, it's the cheapest solution (if you have a casette deck), and it's the most common form of input method on the road for older model cars (the cassette adapter dates back to the early days of the sony walkman!).
Otherwise, the sound quality is worse than more expensive solutions.
I've also noticed the GSM radio (aka: phone and EDGE data) noise is much worse on my friends car with the casette adapter (and the adapter tends to eject itself if there's a longer than normal period of silence between songs) than the USA Spec device I use that hooks up to the CD changer port of my car stereo.
theraker007
Jun 15, 2007
322
I've found the audio to be quite good. Unless you're an audiophile, its a good way to go
Bakerman
Jul 8, 2007
44
PA/USA
I am using it in a Chrysler 300C and the sound quality is the best I have heard through a tape adapter.
Martlet
Jul 11, 2007
145
Well sure, it's a decent tape adapter, I didn't mean to say it wasn't.
Just saying that if possible, an adapter that runs directly into the head unit is going to sound better than a tape adapter can (either built-in iPod support, a line in, or CD changer connection).
I haven't tried it, but I've heard that the devices that connect between the antenna cable and the radio (basically, a hard wired FM transmitter) sound better than cassette adapters or wireless FM transmitters too.
Jul 20, 2007
I want to use my aux. for my iPhone but CANT!
I own a Chrysler 300 and mine didn't come with a tape deck however it came with an AUX input. I have the aux. cable I used with my IPOD and the audio was perfect. Now, when I plug that same cable into my iPhone, I get no audio. PLEASE HELP! I hate FM transmitters. I really want to use my AUX for my iPhone. Am I doing something wrong? Any suggestions?
luomat
Jul 22, 2007
Url?
Do you have an URL or other product info for what you bought?
smak
Jul 19, 2007
Was this online or at the store?
-smak-
Romanesq
Jul 11, 2007
59
You're still in good shape most likely
Probably your jack to the iPhone isn't connecting properly. Take a look at the jack. Is there a small ring at the base that can be easily and safely removed. Go ahead and cut around the circle and remove it. Then reinsert and try it again. You will probably be successful.
The other way would be to get an adaptor. Belkin makes one and I heard the Griffin is a little better. Both about $10.
Good luck and you'll probably be up soon enough.
scrowner
Jul 4, 2007
120
I bought this tape adapter from the local Apple store. This iPod stuff is new to me and I have a tech question:
How should I set the volume on the iPhone when playing through the tape adapter?
I did notice some funny beeping noises while playing music. This happened 3 times during an hour of playing. A previous reply indicated that it may be EDGE connection noises - but I am not sure why that would be as I was only playing music.
This adapter worked fine with phone operation. The song would fade and then I could hear the person through the car speakers. I did need to manually unlock the phone to answer - painful. I simply spook and the caller could hear me fine without having to move the phone to my face.
I really would like to have pure audio input to the car sterio rather than through this tape adapter - but will have to wait to buy something for my cars sterio. This is a nice - cheap start to iPhone songs in my car.
theraker007
Jun 15, 2007
322
i put the volume around 50% on the iPhone and adjust with the car volume, i have no static or noise interference
iLLGT2
Jul 26, 2007
211
NY/LI
You have to start a song on your phone, and while its playing connect it.. I have the dock that plugs into my car cigarette lighter. It wasn't working either when I would put the iPhone on then start the song, but if I play the song through iPhone speakers then put it on, it starts coming out of the car speakers ;)
Goodluck!
scrowner
Jul 4, 2007
120
Thanks for the 50% tip - that was what I was using. Another thing using the tape deck:
How do I avoid always adjusting the cars volume for each song?
It seems for every song I need to increase or decrease the volume. I got all my songs from my own CDs. Again, I am new to this iPod thing, but I am LOVING it! It is sweet to get in the car and have my favorites at my finger tips.
