Apple iPhone external battery
rishidhar
Jun 30, 2007
Hi,
I was just wondering if there was an external battery for an iPhone out yet. Like the iluv for the ipod which makes the battery go upto 52 hrs.
Also do any of the ipod external batteries in the market work with the iPhone?
Martlet
Jul 11, 2007
145
All of the dock connector external batteries should work.
The ones that are custom fit for a particular iPod may not fit. The ones that use a cable all should work.
gcvt
Jun 21, 2007
1,029
San Francisco
xSoNiCcRaCkErSx
Jun 30, 2007
226
be careful, some of the ipod recharging external battery thingies DO NOT work with the iPhone for sum odd reason. theres a thread around him somewhere that states what accessories works and does not work with the iPhone, id find that if i were you before you make a purchase,i know for one my external battery powered usb charger does not work with the iPhone but does with my ipod and other usb charged gadgets.
vansouza
Jul 11, 2007
164
Las Vegas, NV USA
www.usheroes.us
mine works
Hi,
I used it at work yesterday because I was showing off the phone so much the battery was down... not a lot... so I used my iPod external to charge the iPhone... worked great... just gave the iPhone 55 extra hours...
