Apple webapps out already?
KyDuckman
Nov 29, 2007
41
Says there is over 900?
x666x
Jan 24, 2008
443
And about 5 you would actually want to use.
Bone
Feb 11, 2008
1,214
most of them are nothing more than web pages that will format for iPhone use. ive actually sat down and scrolled threw every singe app that appsafari has to offer and i mean come on? how many damn diff soduko games can they posibly produce? sorry just ranting.
Bone
Feb 11, 2008
1,214
im sorry, i wasn't trying to diss sudoku, i was just saying that there are way too many repeat sights out there to sort threw when at the end of all my looking i didn't even come accrose fifty that were worth actually adding to my phone.
again i apolagize Napoleon_PhoneApart
x666x
Jan 24, 2008
443
I actually use Ruler quite a bit... lol
callisto9
Feb 12, 2008
403
IOWA
ugh. web apps. they are moderately acceptable if you're on wi-fi, but on edge, they are useless. i also love the ones with ads on the bottom (sarcasm). :rolleyes:
i can't stand web apps.
x666x
Jan 24, 2008
443
Well after I posted about the Ruler web app, I realized you could just spider the site and view it locally with a JB'd iPhone. I'm going to have a go with localizing the Ruler app after dance class with my better half.
mletang
Jan 23, 2008
120
NYC
www.NYCpetforum.com
x666x how do you spider the site to make it viewable locally?
x666x
Jan 24, 2008
443
Well I haven't found/looked for a solution on Mac, because I still prefer to use HTTrack for PC (under VMware/Leopard).http://www.httrack.com/
One thing I'm still investigating however, is if .js javascript files will work natively on the phone or not, they may need some coaxing through permissions, I'm not quite sure, but a lot of these Web Apps use that stuff, as well as AJAX, which unfortunately doesn't spider.
Sites more likely to spider are the ones that don't use too much scripting on the backend. Simple web apps like a Weight Watcher's Calorie counter, for example, should be able to spider well, but again run into the problem of whether or not the iPhone can parse external script files internally. I will get to the bottom of this later tonight.
