Application Lose
slayer666
Aug 13, 2009
122
I want to jailbreak my iPhone 3g 8gb and wondering will i lose all my apps when i jail break? If so what steps can i take to insure that i don't lose anything? Thanks for any help
Cheers Joe
flabyboy
Jun 25, 2008
769
Minnesota
can't you just sync you're iPhone to iTunes on the new computer after it has been authorized? It seems like this would be easier than manually downloading each app. Won't the sync transfer the apps to the iTunes on computer
Jul 8, 2009
Cheers Joe
you can check \iTunes\Mobile Applications on your PC there are data about apps you have installed, after your jailbroken iPhone, you can find them back
Jul 8, 2009
that's the correct anwser, l did like this and everything is back:eek:k:eek:k
