Application Trouble
Empererred
Jul 1, 2008
37
I installed a few applications that were working fine on the 11th, however, they are not working today. I just click the application and it opens and then closes right away. It is doing this with all my downloaded applications, any ideas?
-Thanks!
JoeT
Dec 18, 2007
911
Tampa, FL
Reboot and see if they work. If not, try reinstalling them. If that doesn't work, you may need to restore the iPhone.
gregneedham
Jul 9, 2007
59
Same thing here, although it varies with the application. Pandora seems to work fine everytime, but Weatherbug, AIM and Sketches, among others, seem to work, then after a while, they launch and immediately shut down.
Deleting the app and re-installing works, but is not a real solution. I may restore the phone and see how that works.
Hoping it is just working out kinks...if anyone has a solution, that would be great.
