applications help
glevere
Aug 28, 2008
my applications that I downloaded for free won't come up like when I touch the screen for the application it's show the main screen then it goes back to the home screen In a second. Can someone help me please thanks.
try hard resetting your phone... (hold sleep button and home button till it turns off) if that doesn't work, just plug your phone into your computer and sync it up... that worked for me
Owgasm
Jul 12, 2008
177
Just resync, if that doesn't work, turn on and off the device.
Should work :)
Kevio
Jul 30, 2008
136
Rachet City
Always go through the reboot processes when you have a problem. Your last resort should be a restore and if after that you still have a problem. You might need a new phone. Thats how I always take care of my problems :D
Hondamaker
May 14, 2007
9,946
671
56
Fairborn, Ohio
I would reboot, and if that doesn't work, then uninstall/reinstall the app.
