Apps don't work on jailbroken iPhone...
dims
Oct 27, 2007
Well I jailbreaked my friends iPhone using the new appsnap installer and it went smooth but I can't seem to open the installed apps other than installer.app and summerboard preferences. I restored the iPhone and reinstalled appsnap but i am still experiencing the same problem.
Before I restore again and jailbreak using another method I used for my own iPhone is there a way i could fix it and get it to work.
Gray
Aug 19, 2007
41
I have the same damn problem.
stevenlue
Jul 12, 2007
Did you install BSD? Not sure what it is but a lot of the apps didn't work on my phone until I installed it. Now they all work.
I think it was under the "system" tab, but not sure since after you install it it no longer shows on your installable apps.
Chris716
Nov 29, 2007
807
IL
yes install bsd or try a restore and start over but either way you need bsd
