Apps icon stuck with 3 showing
JFN
Jul 12, 2008
273
14
Nor Cal
My apps icon is stuck with #3 in the upper right for corner. When I click on it it shows 3 updates available. They won't down load and I cannot download through iTunes. Any ideas?
John
Youngbinks
Jun 4, 2007
7,617
31
Atlanta, Georgia
Have you tried resetting the iPhone by holding down the home and sleep buttons? Try going into Settings and resetting all settings. That should hopefully do the trick. Also, try closing iTunes on your computer and then running it again.
JFN
Jul 12, 2008
273
14
Nor Cal
Thanks the reset did the trick.
