apps in unlocked iPhone
Oct 15, 2007
Hi guys!
I'm new here!
I've just bought one iPhone and it's amazinnggg. However I'd like to use apollo and NES Emulator, but I'm afraid to do so, because it came already unlocked (firmware 1.0.2) and I'm afraid to install the AppTapp and carry on doing what the websites' tutorials teach and get any problem. It my iPhone is already unlocked what am i supposed to do to install third-part apps?
thankzzzz guys!
With installer 3rd party apps, Installer.app is the easiest way. Go to http://iPhone.nullriver.com/beta/ and select your version of iTunes. The download will walk you through the rest. It's basically one click and you have installer on your iPhone.
Now open Installer, click an app you want, and tap Install. ModmyiPhone.com has more detailed guides on how to do this.
Oct 15, 2007
small doubt
thanks.
But i don't know what this installer.app does, will it lock the iPhone again? or it there is nothing to do with unlocking process?
cheers
tonyj81
Sep 25, 2007
69
VA Beach
I think everyone was nervous when they installed 3rd party apps for the first time, but don't worry. Just follow the instructions and you will be fine it is vetry easy. And after that prepared yto be hooked for a while looking at all the options out there for you. Been at it for a few weeks myself and still can get enough!
