Apps like Lockdown Pro
everlastuk
Jan 10, 2012
hi guys im on IOS 5.0.1, and basically ive always used the app lockdown pro but since going up to IOS 5.0.1 lockdown pro don't work anymore, ive also tried locktopus and even iprotect neither of them work, iprotect downloads but a lot of the options don't work, so can someone please help me out and tell me if there is a app similar to the 3 apps ive just mentioned please? i like the fact that i can protect any individual app and even have specific passwords for specific apps and also the disable icon moving and disable app deletion options.
Ive looked everywhere and had no joy, please help.
thank u guys
Applocker is iOS 5-compatible and only costs 99¢.
everlastuk
Jan 10, 2012
OK, I've downloaded applocker, i really like it, but the apps don't lock, folder locking options work, but application locking doesn't, no matter what i try applications wont lock, even if i try the "lock from jiggle mode" the apps just wont lock. Can you confirm you iOS is 5.0.1? if so can you reply back and let me know why i might be getting this problem?
thanks
liberated
Jul 19, 2007
3,238
484
ok I've downloaded applocker, i really like it, but the apps don't lock, folder locking options work, but application locking doesn't, no matter what i try applications wont lock, even if i try the "lock from jiggle mode" the apps just wont lock. Can you confirm you iOS is 5.0.1? if so can you reply back and let me know why i might be getting this problem?
thanks
Go to Settings/AppLocker/Application Locking/ scroll to the bottom and turn the settings on under "Lock Launching apps from" Then your all set :)
fijiman
Feb 13, 2011
832
64
UK
FYI - Lockdown Pro is now IOS 5.0> compatible and available in Cydia...
