Apps Not Working!
Jan 9, 2008
For Some Reason All My Apps Today Won't Work You Click It An It Goes To It For Few Seconds Then Just Goes Back To Home Screen. Anyone That Might Be Able Help Let Me Know Thanks.
Youngbinks
Jun 4, 2007
7,617
31
Atlanta, Georgia
Well that seems as if your Apps are crashing as soon as you run the phone. Are you Jailbroken or are you running stock? Have you tried updating to 2.0.1? I would recommend updating (if you're not JBen) and if you are try a restore and then re-Jailbreak.
evil_ryu
Jul 28, 2008
47
if its apps from Apple try going to iTunes and sync your apps i got that on acouple of my apps and after i did that i got them to work, except for one i cant get?
Aug 11, 2008
My (non-jailbroken) 3G began acting like you're describing after I applied the 2.0.1 firmware update. Any app from the store would begin to run, then simply return to the home page. As an experiment, I downloaded one more free app from the store. Once it was done downloading and installing, my problem was solved for all apps. Give that a try.
