Apps Opening then Closing: Anyone Else?
bp4life71
Jun 19, 2009
Today, I started up the Pandora application and it flashed then flashed off. I restarted the phone..same thing again. I tried the other 5 or 6 apps and they did the same thing. They flashed like they were going to start, then backed out again.
This happening to anyone else.
bp4life71
Jun 19, 2009
Anyone know what could be going on? My apps wont start. Im new to iPhone...any advice?
psylichon
Oct 31, 2007
16,591
751
40
Philly
Resync with your computer, deselect all apps, then select them and resync them. That should get them going for you.
bp4life71
Jun 19, 2009
Oh ok then. Is that a common occurrence? I mean, do I have a faulty phone or is that just part of doing businesss with the best technology available?
bp4life71
Jun 19, 2009
So does this happen frequently where you need to resynch to get the apps working again? Yes, no?
psylichon
Oct 31, 2007
16,591
751
40
Philly
No... it happens occasionally after an upgrade, but there's nothing wrong with your phone.
shutter13
Jan 8, 2009
2,208
153
I thought this was due to apps being incompatible with the 3.0 software so he app doesn't open at all and won't do till an update is released.
Could be some aren't compatible, but when I first "restored a back up" on my 3GS, all my apps ended up n the "Other" category rather than "Applications" re-sync'd and it all went back to normal.
ZipZap
Dec 15, 2007
529
I have had this happen on a 3G...I turn off and turn on the phone and all is fixed.
