Apps won't load updates on my iPad
  1. Ptflute
    Ptflute New Member
    Dec 20, 2011
    I try to load app updates and it starts to do it and then lives in waiting mode How do I fix this?
  2. Ptflute
    Ptflute New Member
    Dec 20, 2011
    I have the original iPad
  3. Avatar
    Sponsored Advertisement
  4. iphonewarrior
    iphonewarrior Moderator Moderator
    696
    Do you have enough free space on the iPad to allow for the updates to download? Have you tried hard-resetting your iPad? Another option would be to download the updates on your computer and sync them onto your device.
  5. Ptflute
    Ptflute New Member
    Dec 20, 2011
    I do have enough space. I tried that- updating them on the computer still didn't sync. .?
  6. Ptflute
    Ptflute New Member
    Dec 20, 2011
    What is a hard reset?
  7. iphonewarrior
    696
    Have you checked the right boxes to sync new applications?
    Hold down the power button and home button together. Release both buttons when you see the White Apple logo. This is what's known as a hard-reset :)
    Is the iPad jailbroken? Could you post the exact error you're seeing as well?
  8. showguy
    showguy Member Silver
    Dec 2, 2007
    The app updates you are trying to download could require OS 5.0 or higher. Make sure your IPad has the latest software update before trying to update apps.
  9. iphonewarrior
    696
    You would see an app compatibility error pop-up appear if the app required a newer firmware.
Share This Page
