Aptbackup app
terrapin
Aug 3, 2009
349
Chicago
so I have this installed on my 3Gs - hit backup - where would I see a "list" of my Cydia apps on the PC/iTunes? where is it being backed up to?
Jun 19, 2007
33,478
4,542
Upper Marlboro, MD
terrapin
Aug 3, 2009
349
Chicago
yeah...
that link just shows the splash screen that comes with the app - I hit backup and it rns for less than a second - I was just curious as to where the apps are being "saved"?
mittenman
Jul 25, 2007
813
Nowhere, Mitten
Aptbackup just saves a virtual list of what you have installed via cydia. After running it on the iPhone/touch, you need to back-up the device on iTunes. after restoring, you need to restore from that back-up, jailbreak, and re-install aptbackup then run "restore". It will not show you a list, it's essentially storing this stuff as a setting or preference.
