Are my iPhones eligible for unlock to work with any carrier?
Danny Biz
Oct 27, 2012
Kacyiru, Kigali, Rwanda
Hey Guys, I have 2 iPhones 3gs and I am confused which one is eligible for iPad baseband update and which one is not. It is very confusing for me to tell by just serial numbers, I don't quite get it. Here is the serial numbers of the 2 iPhones:
  • iPhone 1: Serail Number: 85943H....... iPhone 2: Serial Number : 87012E........
Can someone please tell me which one is eligible for the iPad baseband update? iPhone 1, is jailbroken and Cydia is installed but I am unable ton unlock it so that it can support my carrier. It is running iOS 5.1.1 with a modem firmware of 05.16.05 * I tried the method of v.backspace but it did not work, I also tried Ultrasn0w but it did not work and the Ultrasn0w fixer that I got on Cydia is for iOS 6. can you suggest me what I can as long as I am also afraid to update the iPad baseband for these iPhone? iPhone 2, This one is also jailbroken running iOS 5.0.1 with a Tethered jailbreak by Redsn0w 0.9.13dev4. after setting it I was afraid that the installed iPad baseband (6.15.00) is going to ruin my phone and I immediately downgraded the iPad baseband and after it was stuck into dfu mode, I tried to Just Boot Tethered and it was working again. when I removed the sim card it turned off. I tried to reboot it again using a tethered boot but no luck. I tried to restore it using iTunes with custom ipws and Apple store ipws but no luck. now when I boot it with a Tethered boot of Redsn0w it gets stuck on a white screen and return into dfu mode after a while. * What can I do for this one? I learned about Corona that convert Tethered jailbreak into untethered after that my phone was no longer working. I hope someone there can help! Thanks, :)
Danny Biz
Oct 27, 2012
Can someone please tell me which one is eligible for the iPad baseband update?​
  • iPhone 1, is jailbroken and Cydia is installed but I am unable to unlock it so that it can support my carrier. It is running iOS 5.1.1 with a modem firmware of 05.16.05 * I tried the method of v.backspace but it did not work, I also tried Ultrasn0w but it did not work and the Ultrasn0w fixer that I got on Cydia is for iOS 6. can you suggest me what I can as long as I am also afraid to update the iPad baseband for these iPhone?
  • iPhone 2, This one is also jailbroken running iOS 5.0.1 with a Tethered jailbreak by Redsn0w 0.9.13dev4. after setting it I was afraid that the installed iPad baseband (6.15.00) is going to ruin my phone and I immediately downgraded the iPad baseband and after it was stuck into dfu mode, I tried to Just Boot Tethered and it was working again. when I removed the sim card it turned off. I tried to reboot it again using a tethered boot but no luck. I tried to restore it using iTunes with custom ipws and Apple store ipws but no luck. now when I boot it with a Tethered boot of Redsn0w it gets stuck on a white screen and return into dfu mode after a while. * What can I do for this one? I learned about Corona that convert Tethered jailbreak into untethered after that my phone was no longer working. I hope someone there can help! Thanks,:)
