Are there any application differences when using an iPhone on T-Mobile?
HELPmepLox
Jul 15, 2007
So.Cal
so any differences from application on iPhone after unlock to tmobile i heard u cant use that fancy voicemail and youtube?
i might unlock because then i wont have to be tied to 2yrs and i can travel with it without the at&T roaming rate
el31415
Jul 15, 2007
215
everything work except teh
Visual Voice Mail
instead you get strait to your voice mail
so it work just like a regular voice mail
Youtube works
You will need to change the setting for you EDGE GPRS
HELPmepLox
Jul 15, 2007
So.Cal
was wondering modding my phone connecting to iTunes is all fine right? just shouldn't update because i plan to mess around with me iiPhone and also gettin the nes emulator
HELPmepLox
Jul 15, 2007
So.Cal
it should ask you if you want to update not just do it .. hope that help you :)
i know that but sooner or later you probably wanna update it bcuz it add a new app and fixes so bugs and if my iPhone is unlock i wouldn't beable too huh?
