Are these apps compatible with 2.1?
fdchilds16
May 6, 2008
172
I'm about to upgrade to 2.1. The only issue is that I noticed there are no money managing or grocery list apps for free on the App Store, and I use MobileMoney and ShopList religiously. So, I've been thinking of upgrading to 2.1 and then jailbreaking so that I can still use AppTapp to install the free programs that App Store doesn't offer. However, I'm not sure if ShopList or MobileMoney are compatible with 2.1. Does anyone know the answer to this? These are the two apps that I'm most concerned about.
However, if you know whether or not ThemeBuilder, SummerBoard, Customize, Poof, Finder, Capture, Simplify Media, and OrbLive are compatible with 2.1, please let me know as well. If they are, are they stable? :laugh2:
fdchilds16
May 6, 2008
172
Never mind. I've found other apps that are similar to the ones I'm hooked on.
