AsBattery / Enable battery % meter on iPhone 3G / on Cydia now
iErik
Oct 27, 2007
1,221
72
Las Vegas, NV
AsBattery is available on Cydia now. It activates the battery percentage meter on the iPhone 3G. Once installed do a reboot and then you can turn it on in setting - general - usage.
Source: iphone-notes.de
Ezekiel2517
Sep 20, 2007
693
now if there were only something to activate video recording....
cliffeman
Oct 13, 2007
2,142
80
Feenix, Amizona
Btw, SBSettings has the same thing in their settings as well. the numeric battery setting.
iErik
Oct 27, 2007
1,221
72
Las Vegas, NV
Does the SBsettings one do the battery and percentage side by side or do you tap the battery to see the number?
Ldc4S
Aug 7, 2007
73
Dallas, Tx
I just tried on my 1st gen iPhone as well and it works.
tate
Jun 6, 2009
116
I must be an idiot. I can't find the dang app. But then again I just did my first JB 2 days ago. LOL!
iErik
Oct 27, 2007
1,221
72
Las Vegas, NV
Do you have "allsources" installed? If not go to the sections tab in Cydia and scroll down to Repositories. Install the Steffwicz source and then search for "allsources" and install that. You should then be about to find the AsBattery mod.
tate
Jun 6, 2009
116
I found it on SB settings. Thanks for the help.
eureka
Jun 19, 2007
62
Which app is it that displays one or the other, simply by tapping the battery (or the number) to toggle between the two?
that works when you go into boss prefs...and then the extra's however it is not compatible with os 3.0 i tried already
Sep 2, 2008
Did what you said and still can't find ASbattery.....
Ldc4S
Aug 7, 2007
73
Dallas, Tx
Add the source I listed on the first page and you should find it after you install the source.
glycon
Dec 6, 2010
can you tell me the name of the theme ?
