AT&T 5% text msg
xman
Jun 9, 2008
139
orlando,fl
Yesterday I received a text from ATT stating that I was in the 5% highest data usage category and they will be slowing down my access speed if it continues.
How much will it be slowed? They won't give any details. I am an unlimited user and they did offer to put me in a tiered setup where usage isn't monitored? Sounds weird.
They also mentioned that the apps running in the background are using data. I know I can stop apps individually BUT is there a way to stop all background apps with one keystroke or by using a special app?
thanks
rollinfromhell
Aug 1, 2007
1,232
44
thanks
Very slow. A friend showed me his it was like .2 mbps. So basically, nothing. slower than edge.
You'll need to start monitoring your usage and keep it under 2 GB/month to avoid throttling. Streaming apps such as Netflix and Pandora are often the culprits. Aside from music streaming apps (and possibly free navigation apps that don't have preloaded maps), I can't think of anything that will use significant amounts of data while running in the background. The other option is to switch to a tiered plan. It's $30 for 3 GB data now. Each additional GB is $10. A tierred plan is now actually a better deal for those who use between 2 and 3 GB per month because using that third GB will not put you at risk for throttling.
Apple iAddicted
Feb 20, 2012
269
27
thanks
I'm on the 3GB and doing fine you can go in settings/general/network and turn off cellular data that's what I do and only cut it on when I use it. This keeps any data hogg apps from eating data and makes my battery last longer.
Kadelic
Jan 4, 2010
4,957
1,609
Dallas, TX
Just curious, how much data had you used during that billing cycle and what area do you live in?
The reason I ask is because I intentionally spiked my data usage last month to see if I would get a warning message. I never got one, nor did I experience any throttling. I live in the Dallas area so I wonder what the 5% would actually be for me. It could be they didn't throttle me because of my usual "normal" usage (I've averaged 2.4GB for the past 13 months.) Here's the graph of my recent usage:
Bennyboy
Jul 21, 2010
14,017
1,731
PA
Did you sleep the whole month of October?
I doubled my data last month and got nothing either. I usually, barely go past 2 gigs a month, last month I reached 5 gigs.
iHolophyte
Feb 19, 2012
317
35
Manchester UK
www.youtube.com
That's why I'm glad I live in the UK I have unlimited date with no fair usage and use over 20GB each month as I also tether my wife and daughter to it through personal hotspot when we're away from wifi. This is not a problem with the carrier that promotes this here (three) I have heard unlimited data in the good ole U S of A is rubbish and everyone has their data either slashed or capped.
iHolophyte
iHolophyte
It's still unlimited without throttling with Sprint, but their 3G speeds are slower than AT&T and Verizon.
