AT&T existing customer
Popdevil
Jul 2, 2007
254
I am an existing AT&T (Cingular) customer. If I purchase an iPhone can I take it home, switch sim chips and start using it?
I know you need the data package which is $20 to get email/web and Virtual Voicemail. I just want to know if I'm going to be able to make and receive phone calls out of the box with my old sim chip or do I have to call AT&T anyways.
ximermot
Jun 28, 2007
34
nope, won't work. i had the same idea when I got mine, tried it and didn't work. i previously had a blackjack with a 3g sim card.
wjp09
Feb 25, 2007
2,559
25
NJ
activation is done with sim card imcluded with the iPhone and it is done through iTunes
Popdevil
Jul 2, 2007
254
So they are going to make ANYONE who wants to use the phone service to sign up for the 2 year contract.
art
Jun 29, 2007
88
Apple has some funky sim they preload into the phone and it will only work with that. Plus if you remove it an put it into one of the other phones you have it will cripple that phone. It's to make the iPhone look better.
On the AT&T site, it says that using the iPhone sim in another phone will only provide you with MediaNet services, not the internet. It kills the functionality of your other Phone. I know I tried it.
If you really want an iPhone the best thing to do is prepare to spend a lot of money.
This is what I did, and it's not so much that I really wanted or needed an iPhone, I just did it because I could and would rather not have to trust that an iPhone is reliable enough to take the place of one of my other phones. I must have a reliable phone, and I already do, so I wanted to leave it alone so I would have something that I could count on.
It's kind of like when I bought my first MacBook Pro, it got so hot it blew up and I was screwed. I had to go out and by another PC based laptop so I could continue to work with a computer I could count on. It took Apple over two weeks to return my MacBook Pro and it still was not fixed.
So do yourself a favor and don't make yourself vulnerable to something that may or may not work.
Keep your existing plan and phone number for your current phone. Then start fresh with Apple and AT&T. They will sell you a Second Two year contract, a new phone number an Apple proprietary sim and then you will have your iPhone. A very expensive solution as it will double your cell phone bill, but you will have the safety of knowing you have one phone that works.
Then you will be safe.
mach1mustang_101
Jun 30, 2007
59
anyways. just buy the phone take it home hook it up to iTunes and you'll be running in no time. as long as your sim works like its supposed to. its just gonna be 20$ more then what you pay already.
