AT&T iPhone 5 problem switch between WiFi and LTE
Redbull2000
Dec 4, 2012
121
9
Minnapolis
I had problem with the wifi turn on on my ip5 but when there is no wifi signal, the phone instead switch to 4g or LTE, it will stay no service or a long while before reconnect again, anyone ?
Sent using iCafe app
Rafagon
Dec 7, 2011
7,567
1,227
46
Miami, Florida
If you're stuck for a long time with "NO SERVICE" displayed, I would recommend toggling Airplane Mode to ON and right back to OFF to see if it helps. If this still doesn't help, I would take it to an Apple Genius and have them take a look at it.
I'm on AT&T myself, with an iPhone 5, and I've noticed "NO SERVICE" sometimes staying on a little bit too long when going from Airplane Mode ON to Airplane Mode OFF... But usually no longer than a minute. I haven't observed to see if the same happens when leaving my Wi-Fi signal...
Redbull2000
Dec 4, 2012
121
9
Minnapolis
I did turn on the airplane mode and switch off then will back to normal. But this issue has become very annoying. Thanks for your help anyway.
