AT&T MMS on 3.0 working?
Oct 12, 2007
24
Has anybody tried the Gizmodo hack on the Official 3.0 release? Is it working? Please post your findings and How to's
Oct 12, 2007
24
ok i'll be the guinea pig. im downloading the official 3.0 as im typing this. i already have the ATT ipcc file. I will let yu guys know if the tethering and MMS works. Good luck to me;)
dutchtrumpet
Jul 13, 2007
31
release and GM are exactly the same. Nothing for an individual will change.
Oct 12, 2007
24
ok so how do i do an Option-Click on iTunes on Windows? Im having trouble loading the Ipcc file?
Adam1389
Nov 20, 2008
588
Ilwaco, WA
If you are running the latest iTunes, you can't load IPCC files with it.
Oct 12, 2007
24
Im running the Pre-release itune 8.2. I was able to load the IPCC file i got the tethering working but the MMS setting did not update for me. should i input it manually? I can pull it from my HTC Fuze.
Adam1389
Nov 20, 2008
588
Ilwaco, WA
Be aware if you do get it working right now, if you have an iPhone text plan, it doesn't include MMS, so you get charged per message.
Oct 12, 2007
24
i have the medianet plan. from my razr V3 sim that im using. I couldnt figure how to send MMS tho. any ideas?
phop5
Nov 23, 2007
39
Wow! Was there an answer somewhere in those 9 post ?
Oct 12, 2007
24
okey guys here's what i did so far
Installed 3.0 official released
Got the tethering hack working just fine.
Loaded the carrier update
But The MMS toggle on/off switch is GONE...yes GONE! I don't know if the official released removed this.
I tried to roll it back to 3.0 GM version but iTunes is saying wrong firmware version. What should I do now? I should have stuck with the Beta version.
Any Ideas?
