AT&t Phone
newark
Dec 16, 2008
I bought iPhone two weeks ago and upgraded to 2.2 (mistake)? Can /should I use restore to remove the upgrade? Especially if I consider jailbrake?
Nov 14, 2008
6,844
414
26
Cairo, Egypt.
If you're a legit AT&T user, you can jailbreak 2.2.
If you're an AT&T user, user QuickPwn 2.2 on Windows http://www.quickpwn.com/2008/11/quickpwn-22-jailbreak-download-windows.html
Or you can use PwnageTool 2.2 on Macintosh http://www.iphonehacks.com/2008/11/jailbreakunlock.html
Scroll down the page of the PwnageTool 2.2 in order to find the Download links.
Good luck mate.
PS: If you're wondering what is the difference between Pwnagetool and Quickpwn - PwnageTool gives you a better chance of being able to use any Software Unlock that is released in the future, since your baseband will not be updated, and also you NEED to use PwnageTool if you are not an AT&T user and are using a sim chip (Turbo SIM); on the other hand, if you're an AT&T user you can use QuickPwn but your chances of being able to use a Software Unlock in the future will decrease.
icemanplh
Dec 17, 2008
missouri
the only diff i know is that the pwnage tool is specifically for mac products and wont wrk on windows
Nov 14, 2008
6,844
414
26
Cairo, Egypt.
That is true, they did not make a Windows version yet. Anyway, as I said, it will give you a better chance to use a Software Unlock in the future, on the other hand, QuickPwn won't.
