AT&T SIM with legally unlocked iPhone
robhon
Mar 17, 2007
620
Does anyone know if I can buy a legally unlocked iPhone in Hong Kong and still use my same ATT sim in the USA?
I only want it to be legally unlocked so that I can pop a sim chip in when I'm working in China. (Which is frequently. I'm there once every six weeks.)
TIA :)
Saverino
Jun 1, 2008
4,480
92
Burbank
TIA :)
Isn't that the purpose of an unlocked phone? ;)
Yes, you will be able to do that.
Marianne
2,326
29
Massachusetts
marianneschultz.com
Saverino is right. I have a factory-unlocked iPhone from New Zealand and just popped in my AT&T SIM and it worked right away just as you'd expect.
chazm
May 1, 2008
729
40
If you are worried about the legality of this situation, then yes....its legal
TIA :)
Yes, it definitely works, I have a friend who did the same.
Ace2009
Jan 12, 2009
Definitely legal
