AT&T & Unlocked iPhone - Voicemail?
May 30, 2008
I am using an unlocked iPhone with my companies AT&T account. This acct is not supposed to support an iPhone, but i took the SIM out of my Blackberry and put it into my iPhone.
Everything works flawlessly.. EXCEPT... Voicemail
When i try to dial VM using the VM btn. Nothing happens. is there a setting i need to change? A hack/mod i should know about?
andrew79
Aug 27, 2007
The iPhone voicemail uses a different voicemail system. You can probably call AT&T and get them to activate it.
May 30, 2008
I thought about that, but than won't they want my company to pay for an iPhone acct? as as AT&T and my company knows, i am using a BB. of course my local IT guy knows i swapped SIMs.
andrew79
Aug 27, 2007
That's true. They might want to force you to get an iPhone account. I guess it's up to your company now. You can still use the normal voicemail . I would goto to Settings - > General - > Reset and reset the phone setting. I just sold my iPhone so I don't remember where the buttons are.
May 30, 2008
btw. i used this phone unlocked on T-Mobile and VM worked.
and i don't neccessarily care about the Visual Voicemail feature, i just want VM.
andrew79
Aug 27, 2007
Just reset your phone setting then . Your voicemail will work then. What I usually do is I'll reset the setting and then wait for a minute or two and click on my voicemail and wait for it to call voicemail.
May 30, 2008
so odd. i reset Networ Settings, and no change. the VN btm "highlights" and does nothing.
May 30, 2008
sold your iPhone! BLASPHEMY!
andrew79
Aug 27, 2007
Lol I'm waiting for iPhone 2 . There's no reason to own two...
Saverino
Jun 1, 2008
4,480
92
Burbank
They know you're using an iPhone. If you're able to check online, itll show you're using an iPhone and not a BlackBerry even though you're on an BB plan.
Jun 7, 2007
545
Queens, NY
you might have to activate the att voicemail....meaning call att....they know your using an iPhone....
