AT&T vs. Verizon, does it really matter?
MNJON
Nov 21, 2007
164
9
Minnesota
Since these are not linked to my iPhone service in any way... is there a reason why I could not pick either of these to go with? Is one service better than the other? My current iPad 2 is an AT&T one.... but.... maybe Verizon offers something better for rates?
Any thoughts? Is Veriszon as good? Is their coverage as good?
Thanks!
MNJON
Nov 21, 2007
164
9
Minnesota
Verizon costs more.... I use AT&T and the $15 per month has been enough... so far. If I go to V... the lowest price is $30 per month for 2gb.... AT&T would be $30 for 3GB!
I'm not sure Verizon would be a plus for me. I cant see any benefit except that IF I visit Montana, the coverage would be better.
Hmmmm
CASEACE79
Mar 29, 2009
409
47
Well it does matter but only to you. Do you live in an area or would be using your iPad in an area where AT&T or more likely Verizon has 4G towers? If so then that could sway your decision. If 4G data speeds are important to you that is. Look at 4G coverage areas for both in your area. If you're on the road a ton without wifi Verizon does have an 10 gig per month plan where AT&T does not. At the end of the day both will work fine on any 3G tower so look at your personal needs and make a choice accordingly.
Target
Oct 16, 2008
1,139
161
The Great State of WV.
Simultaneous voice and data is only on AT&T. I've never been on vz but I'll tell you I use this benefit.
Target
Sent from my iPad2 using iCafe app
MNJON
Nov 21, 2007
164
9
Minnesota
Target
Voice and Data at the same time, on an iPad? How would one use that feature?
Target
Oct 16, 2008
1,139
161
Huh...how did miss that? I read each post. I must be real tired.
Ok YES! I use my iPhone headphones and the Talkatone app with my google voice account for voice and data on the iPad.
How's that? I'll be better tomorrow I promise.
Target
Sent from my iPhone 4 using iCafe app
GailLA
Nov 13, 2007
265
35
Northern IL
Everyone has different needs, so I don't think there is a blanket answer. I stayed with AT&T. Not that I particularly like AT&T, but I do like their basic wifi hotspots. If you have any plan at all on your AT&T iPad, including the smallest, you get free basic attwifi. If you go to Starbucks, McDonalds, or stay at Hilton hotels this is very handy. It is also seamless after you connect the first time. I have two planned stays in Hilton hotels coming up and it is so nice to be able to download things over the now 50 Mb limit, among other things, at no additional cost. You can find their hotspots here: http://attwifi.know-where.com/attwifi/. Since this is a feature that I use and that I like, I'm sticking with AT&T.
Sent from my iPad using iCafe app
CASEACE79
Mar 29, 2009
409
47
AT&T wifi hotspots have been free for a couple years now. AT&T realized that businessses were just installing routers and offering it for free. It didn't make sense trying to charge for it anymore. I worked at Starbucks while AT&T was still trying to charge for wifi and it turned away a lot of businesss since the cafe right around the corner had free wifi. I still frequent that same Starbucks and I can connect with my Verizon iPhone and my wifi only iPad.
L.I. Bruce Fan
Jul 14, 2008
144
Hmmmm
Verizon has 1 gb for $20, not sure if they offer anything cheaper than that...go with the plan and service coverage that is best for you.
