Auto app updates
Jdsmitty10
Oct 19, 2010
229
14
I just plugged in my phone to the computer to back up and sync etc. and found that I have 24 apps that need updated.. I have auto a update selected in settings. What could cause the apps not to update?
Sent using iCafe app
Dec 15, 2008
5,386
340
27
Pensacola, FL
Hello. I believe the apps update on your iPhone, but of course iTunes can't update them as iTunes isn't open/active 24/7. It wouldn't update them even if iTunes was open unless you went to check for updates and clicked update all. It happens to me as well and I'm sure all of us, yeah? Don't worry about updating them on iTunes daily. If you're going to update your iOS or restore, just make sure you do a backup where it will then ask if you'd like to update those apps on iTunes.
Jdsmitty10
Oct 19, 2010
229
14
When I saw this on iTunes I went in settings and turned off auto updates and it shows 24 needing updated on the phone now that I turned that feature off though.....So.. it seems it hasn't updated in a while
Dec 15, 2008
5,386
340
27
Pensacola, FL
So you're saying because you had the auto update setting turned on, on your iPhone, it was not updating? I believe the iPhone is like the Macbook Pro in this situation. It doesn't auto check for updates until later at night. For me though, I like to check often. :)
Jdsmitty10
Oct 19, 2010
229
14
I have had auto update on since it was available. When auto update is on there is no badge app icon on the app store icon. So when I saw that there were a lot that needed updated on iTunes(not knowing they needed updated on iTunes as well) i turned auto update off to check and the badge showed up with 24 needing updated. I doubt 24 updates came out just today?
Dec 15, 2008
5,386
340
27
Pensacola, FL
I have had auto update on since it was available. When auto update is on there is no badge app icon on the app store icon. So when I saw that there were a lot that needed updated on iTunes(not knowing they needed updated on iTunes as well) I turned auto update off to check and the badge showed up with 24 needing updated. I doubt 24 updates came out just today?
Nonono 24 updates shouldn't be all in one day lol...no way..? But the way auto updates works is it will check and update at a certain time each night, but you can still manually check and update apps on App Store on iPhone. That's what I do.
Jdsmitty10
Oct 19, 2010
229
14
I think I am just going to leave it off and do it manually for now on... I am wondering if it is the cause of my random shut off over night problem...
Jdsmitty10
Oct 19, 2010
229
14
Checking for updates manually I still like to do. Are you saying your iPhone randomly shuts itself off at night?
yes occasionally. the thread on that is near the top of the iPhone 5 page... it has done it when in use too.. have to do a reset to get it back. has happened twice at night while plugged in and fully charged..wont turn back on unless i hold home and lock for 10 or more sec...
Dec 15, 2008
5,386
340
27
Pensacola, FL
maybe 7.1(which is in the process of installing right now) will fix both issues?
I will leave that question open to others, such as Napoleon. However, I will say that updating and or restoring can fix things a lot of the time. :)
You just like to hear yourself talk, don't you? :D
Technically, I am not "hearing myself talk."
rambo47
Apr 4, 2010
528
79
Northern NJ
Just a cautionary note - auto update drains your battery faster than manual updating. Disabling it is one of the prime tips for extending your battery life.
MrMike6by9
Nov 16, 2008
1,482
120
69
Maryland, USA
On the other hand, doing a manual update of say 10 apps at a time, ties up your phone when you might want to be doing something else at the same time. Just saying'
