Auto-Connect to Hidden SSID
plopy
Jul 2, 2007
I have a hidden wireless signal (SSID) at home, with no wireless security.
Although it is easy enough to add a hidden network by entering the name in the "Other" field, the iPhone refuses to automatically connect everytime I am within range. In fact, it disconnects everytime I lock the screen.
Any tips on keeping the connection active?
Thanks,
Jacob
staldor
Mar 15, 2008
I did not have this problem earlier when i used my iPhone under firmware 1.1.1 and 1.1.3. But since i upgraded to 1.1.4 I have the same problem as you describe (took a restore to 1.1.4. and used ziPhone to unlock/jailbreak). Hidden wireless ssid will not auto connect. Since this worked for me before there should exist a solution to this problem.
