Auto-lock
superchaos
Feb 20, 2013
84
I think after updating,when watching youtube videos after about a minute or two my screen first goes to dim then soon goes to sleep or locked.Is auto lock the only setting because I believe that's always been set at 1 minute and haven't had that problem for a long time.
Dec 15, 2008
5,386
340
Pensacola, FL
I take it you're on iOS 7.1 now correct?
I would say it may have to be something to do with iOS 7.1. I'm on iOS 7.0.6 and it doesn't auto lock when watching YouTube videos.
Dec 15, 2008
5,386
340
Pensacola, FL
Did you figure it out? I can't seem to find anything about it. I would not believe that they'd make an auto lock change like that. As long as there is something playing on your iPhone like YouTube, it should not lock.
superchaos
Feb 20, 2013
84
I just set auto-lock to 2 minuets because it gets annoying touching the phone to keep it from sleeping. When I first got ophone 4 over a year ago it did this but I think after updates it was gone but is doing that again.
Ledsteplin
Oct 29, 2013
4,824
987
65
Florence, AL
Your iPhone should not go to sleep while watching a video. It's not a 7.1 bug. I've never heard anyone else complain of that issue. Try a hard reset on your phone. Hold the top button and the home button at the same time until the Apple logo appears. Then release. You might also try deleting the YouTube app, then installing it back.
silvermoon
Jul 17, 2013
1,624
179
Washington
Yeah. That is unusual and not normal behavior. I would check your settings.
Ledsteplin
Oct 29, 2013
4,824
987
65
Florence, AL
You might also try Reset All Settings. Go to Settings>General>Reset>Reset All Settings. You will not lose your content.
You should not have to set auto lock on 2 or more minutes to watch a video.
superchaos
Feb 20, 2013
84
I just rebooted my phone and it fixed the problem.Hopefully it stays good.THANKS
xman
Jun 9, 2008
139
orlando,fl
My 5s is locked in 30 second mode and when I go to settings>general>auto-lock, the auto-lock is dim so can't change it to another value. any help on this..
Rafagon
Dec 7, 2011
7,566
1,254
44
Miami, Florida
You're in Low Power Mode, which forces the Auto-Lock time to be 30 seconds. Turn Low Power Mode off (Settings > Battery) and you will once again be allowed to change the value of the Auto-Lock setting.
