Autocomplete of Email Address Issue
Dec 9, 2008
Is there a way to delete addresses from the "auto complete" email address feature when composing new mail? When you start typing a contact name the iPhone gives a list of possible matches for you to choose from. Some of those suggestions are either out of date or addresses I only used once. Is there a way to delete them so the iPhone doesn't offer them to me in the future? Thanks!
psylichon
Oct 31, 2007
16,591
751
40
Philly
Unfortunately, no. There are no user controls for that feature. If you have out-of-date contacts, why not clean up them up a bit?
Hoshtaylor
You can't...I posted a thread on this a while back...I even tried erasing the phone and re-syncing. That did not work, so don't bother going through that 2 hour process Murphy5156.
psylichon...I know exactly what he's talking about. We can delete the contact from our phone and outlook, but once you've used it or replied to it on the iPhone, it keeps it there (as a temporary file I guess) and there is no way (that I know of) to delete that off the phone.
Picazzo
Jan 21, 2008
2,808
Copenhagen, Denmark
That one is new to me! I thought that the addresses showing up in the mail application only is from my contact list/groups, and not some mail address(es) I only have used one time!
I know Outlook are doing this, and you can easily change the settings for this.
Hoshtaylor
I just wanted to update these two threads on this topic...I imagine that it's been nearly 2 months now since I tried to delete the temporary email address that I wanted to delete....long story short...it's gone now.
So I would have to assume that after all the things that I tried and didn't work, my best guess is that there is some kind of time limit or expiration for temporary data that is not used so it's then cleared/deleted. I'm not sure how long, but this seems to be the logical explaination.
Thoughts anyone...?
loopyl00
Dec 26, 2011
this piece of software allows you to see recent emails that you've used (not in your contacts) ibackupbot http://www.icopybot.com/itunes-backup-manager.htm
It uses the latest backup so backup before you start - then use the widget at the top to view recent email addressees, remove the offending ones and restore back to your phone - much better solution that going back to factory settings
