Automatic downloads.
iP5
Sep 7, 2010
2,964
136
Toronto
I've bought some songs on the PC and the iPod touch has automatic downloads of music enabled.
So when does it download or is there something I have to do to trigger it?
TIA
Sent from my Nexus 4 using Tapatalk 2
iphonewarrior
13,847
699
TIA
There is no such thing as an iPod touch :p
Once you've enabled Automatic Downloads it should just sync over. I don't think it's instant, it may take a little while. I usually find it's under an hour. If I download an app on my iPhone 5 it usually appears on my iPad shortly after.
iP5
Sep 7, 2010
2,964
136
Toronto
Thanks for the reply. Been about 5 hours and no such luck. I'm guessing the Wi-Fi goes to sleep when the auto lock kicks in.
There's no why to have that sleep function disabled when it's on a charging cable is there?
Anyway, manually setting it to never and hoping the songs start downloading.
Sent from my GT-I9300 using Tapatalk 2
iphonewarrior
13,847
699
I'm not too sure then how it works unless you use iCloud. When my phone connects to wifi when it's locked it performs an iCloud backup. Therefore syncing all my 'stuff' - but like most things Apple, it should just work...
Sent using iCafe app
Docd
Oct 16, 2011
651
62
The automatic download will only work with new songs purchased after it is turned on not on songs already purchased. Same goes for apps.
  • Like
Reactions: iP5
