AUX connection?
iphoneFL
Jul 6, 2007
61
Hope this isn't a stupid question..I just got a new car, which has an aux connector. What connector wire do I use to connect my iPhone to play music in the car?
Thanks!
GADeputy
Jan 21, 2008
381
Georgia, USA
iphoneFL
Jul 6, 2007
61
so there is no cable that doesn't require an adapter as well?
GADeputy
Jan 21, 2008
381
Georgia, USA
No I'm confused. After doing a ton of searching it looks like the first cable that The Apple posted is all that is needed.
Can someone that knows please reply to this. I read somewhere that the iPhone will only work with the type of audio connectors that I posted pictures of. Something about it needed the 3 ring type of connectors. That's why you can't use standard headphones in an iPhone.
Anyone know for sure?
iphoneFL
Jul 6, 2007
61
I've used Bose headphones with my iPhone. The connector that goes into the iPhone has two rings.. I did actually have a problem with a set breaking after I used them a couple of times (sound would only come out of one side).. Are Bose headsets not compatable with iPhone?
The Apple
3,105
Indiana
Read the reviews on the cable I posted and you will see there is no need for an adapter. It works perfectly with the iPhone.
termleech
Sep 7, 2007
1,154
McPherson, KS
Assuming that your AUX input on your stereo is 1/8" stereo input, then the cable that the Apple linked will work without an adaptor. It's designed to fit in the recessed headphone port of the iPhone. The reason that some people were saying you needed an adaptor is that most stereo cables that are not designed for the iPhone are too big to fit in the recessed jack of the iPhone, but this one will work fine.
psylichon
Oct 31, 2007
16,591
751
41
Philly
FYI, the 3-conductor connector (tip, ring, sleeve) carries stereo audio (left, right, common ground). The 4-conductor tips add a microphone signal (for earbuds that have them, like the ones that came with your phone). The 4-conductor recepticle on the phone is designed to also accept 3-conductor connections, as long as they fit in that annoyingly recessed hole.
The 4th conductor you see on most iPhone headphone adapters is tied to ground and does nothing.
Just thought I'd clarify for those who give a hoot.
