Background audio
zandrik
Jul 27, 2007
175
I'm jailbroken on iOS 5.0.1. iPhone 4. Recently I can only play audio if I have the app open. For example pandora will only play if that app is open. If I hit the home button music fades out. This is the case with any audio app. Before, these apps would run in the background. I could even lock the phone and the audio would continue playing. I've scoured the internet and haven't found a solution. Does anyone have any suggestions other than re-jailbreaking?
Thanks!
Bennyboy
Jul 21, 2010
14,017
1,731
PA
I tried to recreate the problem, turned stuff on and off but mine still works and I'm jailbroken also. Look at what you have installed from cydia, other audio tweaks if you have any, and uninstall them, that including snow cover4. Give it a good hard reset and try again.
