Backgrounder problem!
jetson22
Jan 15, 2009
78
Help, I can't get this app to work. I downloaded it then turned on the applications I wanted to enable. When I bring up Pandora and start it then push the home button it says backgrounding disabled eventhough it is not. Thanks.
CBRfanatic
Feb 28, 2008
302
Bronx
if you set it to automatical enable background via the settings for it, then when you open it, it is automatically set to on, holding the home button briefly allows you to exit the app fully without it staying on, but once you open it again, background is automatically on again.
