Bad ****tail?
Picazzo
Jan 21, 2008
2,808
Copenhagen, Denmark
Hi guy´s
I wonder if Caterpillar, Customize 2.0, Summerboard, Poof is a bad ****tail or do they work fine together?
I have installed them all, and they seems to work fine. But should I uninstall Summerboard?
Thanks..:laugh2:
CBRfanatic
Feb 28, 2008
302
Bronx
Hi guy´s
Thanks..:laugh2:
I have customize 2.0, summerboard, and poof all installed, work fine together. Just in summerboard you have to choose customize as your theme in order for customize themes to work.
you have the new caterpillar? How is it? I had the free one and deleted it due to issues.
Picazzo
Jan 21, 2008
2,808
Copenhagen, Denmark
Thanks!
The Caterpillar are really cool! You can customize some wild things here! Try it out, - I think they have 3-4 days trial. One of my favorite on this app, is the calendar function on the "login" screen! I also think its a really cool thing the Caterpillar are inside your settings menu..
