Barely audible tones / no sound/ iPhone 5
Terry M.
Feb 27, 2009
728
84
46
Des Moines, Iowa
I had this problem on my iPhone 4 and so I knew what to do to try and fix it, but as far as I can tell this is the first time anyone has reported it happening on the iPhone 5.
If this happens, more than likely, you've had earphones or some type of cable plugged into the earbuds port. Try putting the plug back in and pull back out rather rapidly a few times. Surprisingly this seems to fix the problem. It did so on the older versions of the iPhone too but for those of you that are new maybe this will help you.
It seems the phone gets "stuck" for lack of a better term, in headphone mode. Really wish this is something Apple would fix in their upcoming phones.
Jerome G
Jul 12, 2010
245
I'll try it, I have a problem where all of the tones/alerts are low except for the ringtone
djwindsor
Jul 7, 2009
755
44
Neponsit, NY
I remember having this issue on my iPhone 4 as well. I had to repeatedly insert and remove my thingy :eek: many, many times. Finally I was able to gain back audio without being in headphone mode. I hope this doesn't happen with the iP5!
coop1701
Jun 30, 2007
899
114
43
Sometimes that does happen. The phone thinks the jack is plugged in. But you also need to remember that you have 2 volumes. Ringtones play via the ringtone volume. System sounds play via your music volume in the music app. Pull that up and make sure your volume is equal to the ringtone volume and your other notification will be louder.
Terry M.
Feb 27, 2009
728
84
46
Des Moines, Iowa
Good additional point!
JDem
Jan 19, 2011
265
27
NNJ and Central PA
There is a whole new thread on the Apple forums about sounds vanishing on any phone running iOS 6! There is clearly an audible bug in 6!
Hayesimus
Apr 12, 2012
261
47
Yes my Facebook app is silent even though the rest are audible. I even deleted it and downloaded it a second time. No change.
Hayesimus
Apr 12, 2012
261
47
I prefer to know when I get an alert. I mean I paid 400 dollars and a 2 year contract for a phone that functions properly. They really need to address the issue.
nealh
Apr 3, 2008
699
25
Wow. Excellent advice. Thanks
