Batch Image Renamer?
Grayburn
Sep 23, 2010
115
14
London, UK
Anyone know of a good batch image renamer that'll work on Windows 8?
I have 3 folders of photos from my 4, 4S and my 5 and as you know all are named IMGXXXX so i cant drop them all in the one folder so would like them all in date order.
Hope someone can help.
radtechy
Jul 20, 2011
505
41
I have 3 folders of photos from my 4, 4S and my 5 and as you know all are named IMGXXXX so I can't drop them all in the one folder so would like them all in date order.
If you have them all stored on the PC just highlight all using control+a then right click and do sort by date and then do oldest to newest or vice versa.
If you wanna see the dates add that column on windows explorer and then click it on the bar and it will order sort it. Just like if you sorted a playlist in iTunes
Sent from my iPhone 5 using Tapatalk
Grayburn
Sep 23, 2010
115
14
London, UK
I found an app called Namexif that did the trick. Converted near enough all my images. Bit strange that it didn't do a few but I'm happy with it.
Thanks for the reply though mate, cheers.
Sent using iCafe app
GAO
Aug 9, 2008
55
Oklahoma
Canon has software that will do that. It will work with raw or JPEG format. It's called Digital Photo Professional.
