Battery doesn't last.
Agent6
Sep 29, 2008
21
New Jersey
I just updated my unlock tmobile 8g ipone to a 2.2. I noticed that my battery seems to consume faster than it use to. Is there something I can do?
aggieman
Jul 6, 2007
4,053
85
Dallas, TX
have you tried the usual methods of turning down the screen brightness and turning off bluetooth and wifi when not in use? I usually keep my screen brightness around 25-30% and it still is plenty bright.
BigCiX
Jul 11, 2008
1,445
Bakersfield, CA
also turn fetch off to receive email.
when using your ipod turn off the eq.
if your unlocked iPhone allows 3G turning that off will also consume battery life.
musicmanmu
238
WV
Have you guys ever tried charging your iPhone (using the wall charger) while its switched off? My iPhone's battery seems last longer that way.
Charge while it's off? When I charge my iPhone and it's off, as soon as I plug it in, it automatically turns on.
