Battery drain and third party apps
Hooshka
Jul 10, 2007
Berkeley, CA
Anyone notice that the battery drains faster after using Installer to install third party apps? My suspicion is that it has something to do with the BSD subsystem and Dock. Anyone else notice this?
RchGrav
Jun 8, 2007
242
Yeah, I was kinda wondering if that was happening too.. I was figuring that wasthe case, or maybe just because I am using it so much while hacking away. Also since I often turn the phone off and on (Summerboard) you can't see the usage data to be sure.
Does seem a bit quicker on the drain to me though... Anyone else?
Yep. Mine drained in about 5 hours.
adseguy
401
I don't notice too much as far as standby time is concerned. When I use the phone and apps then i do:p.
micah67
Jul 9, 2007
11
I noticed this exact issue, too. I haven't tracked down the specific culprit. It's a significant difference - it feels like half the time before remaining juice becomes critical...
theraker007
Jun 15, 2007
322
i still get 1.5 to 2 days on a charge, thats fine for me
jerrettpaul
110
Denton, TX
mine doesn't drain fast unless im using the installer a lot. then it drains just as fast as when i used to use youtube and safari all of the time.
iammike
Sep 5, 2007
I would think anything that ran constantly like Summerboard and Dock would effect battery life. Most other apps only run if you ask them to run.
Sep 17, 2007
I get about a day using the phone for talking, listening and playing with 3rd party apps. I put installer.app as soon as I got it, so I don't know if it drains quickly or not. I want to know how in the world the battery lasts for 2 days for theraker007. I wish mine did that.
burniksapwet
Jul 5, 2007
553
I've notice that too. And did you guys notice that your usage stat will reset back to (-) for some reason. I really can’t figure out how it does that. Does somebody know? I can never remember to check it after I mod something to find out what triggers the reset.
Sep 17, 2007
I think it resets because summer board restarts it every time you change something.
PhatKid
Jul 25, 2007
128
Ah, I thought I was the only one. I dislike that. But I'm not willing to give up the third party apps for the longer life. Hopefully it'll work out eventually.
