battery dying
tumi747
Feb 16, 2008
I just bought my iPhone in december. I worked great until a couple of weeks ago. The battery is at the point where it dies in 11 hours. My daily usage is literally a few short calls (under 10 minutes each). I may also use a couple of apps like the calculator or weather app. I used to use the safari and iTunes all the time but my phone won't last long if I use it now. any one have any experience with this? I am hoping since I have only had the phone a couple months that Apple will either fix it or replace it.
kakofonix
Oct 2, 2007
596
Turn off Wifi (Settings -> Wifi) when you're not actually connected to your home wifi or a hotspot. Unless you do this, your phone continuously searches for a network to connect to and that drains the battery fairly quickly.
aggieman
Jul 6, 2007
4,053
85
Dallas, TX
also check settings on how bright u have your screen
this is the biggest one right here. make sure to turn the brightness down to about 30 %. also like a previous poster said, make sure you mail is set to check manually unless you need it to automatically check. also check your EQ under the ipod settings. turn the EQ to off unless you are using the iPod.
nikeplayer222
Jan 23, 2008
34
Michigan
and make sure your mail settings are on check manually... because then your phone will continuously connect to the internet to get your email... this worked for me
Why can i not find that setting? i'm under mail in "settings' and there's not an option to turn it to manual. Am i a noob or is something wrong?
