battery icon request
PEESKI
Jul 27, 2007
34
over at modmyiPhone.com i downloaded the indigo battery. but it doesn't come with the small batter that's located in the upper right. can anyone make me those files so my battery on the upper right will also be indigo. thanks.
ColPhorbin
Jun 29, 2007
51
in the downloads section of modmyiPhone.com there is an icon set called too many blue icons or something like that. Find the Default_BatteryInsides.PNG file and put it in your main mod folder. then copy it and make another one and name it FSO_BatteryInsides.PNG. They go to system/library/coreservices/springboard.app... Its not the exact same color blue but its a small blue battery in the corner like i wanted. If yourr good with photoshop you could edit that file and if you do that let me know
