Battery in iOS 7.0.4
lancer_325
Jun 9, 2010
212
19
Anybody else having battery drain issues since updating to 7.0.4? I'm down to 20% after only 7 hours 45 mins as opposed to my usual 10+ before. My usage has not changed much since the update so it's not a new app or overuse. Of course Apple will refuse to address this as per every other battery drain issue. I'm deciding whether to ditch Apple completely from now on because of this shoddy attitude to their software making the device suck juice. Any other views?
Ledsteplin
Oct 29, 2013
4,849
1,001
66
Florence, AL
My iPhone 5 is about the same on iOS 7.0.4 as any other 7.0.x or iOS 6.1.3. I get about 9 1/2 hours per full charge. Average.
Sent using iCafe app
Dec 15, 2008
5,386
340
Pensacola, FL
I am not even on iOS 7 yet. I am on iOS 6.1.2 and my battery is horrible. I feel like I have to calibrate it now every day!
5,578
Mine seems the same. I would restore to factory settings before considering something as drastic as switching phones.
flatbacks21
Sep 21, 2010
342
9
Ohio
I am on iOS 7.0.4 and my i5 has shown significant battery drain as opposed to 7.0.3... I too am disappointed b/c while I'm at work for 8 hours, phone is on but not in use and after I take the phone off the charger at 5am, and leave work at 3:30pm, phone is well under 50% with no use, just on stand by.. When running ios 6, I would be at or around 80% after the same time period.. Dunno what to think, love my i5 but hate the battery now..
5,578
Sounds like a poor cellular connection is zapping the battery while you're at work. How is your signal strength there? Have you tried resetting your network settings or restoring?
flatbacks21
Sep 21, 2010
342
9
Ohio
I have turned off network and just used wifi.. Still issues
Sent using a karate chop!
flatbacks21
Sep 21, 2010
342
9
Ohio
Did that about a week ago.. Might have to find an Apple store to see what's up
dmoskaluk
Mar 22, 2013
307
46
66
Paynes Bay - Barbados
My mini has always been a bit weak in battery life when compared with my wife's iPad 2 . Both are basically configured the same way in whatever settings could pertain to battery use. This has been the case in both iOS 6 as well as iOS 7 .... I attributed it to the fully size iPad simply having a bigger battery (?)
radtechy
Jul 20, 2011
505
41
I have 50% left with 10 hours of use and 2 days standby on my ipad mini retina using 7.0.4
I leave wifi on and Bluetooth all the time cause I stream a lot of music with Sirius XM to my LG tone BT headphones.
I never bothered to update to 7.0.4 on my 5S cause I'm satisfied with it on 7.0.3
Sent from my iPad Mini Retina with Tapatalk
dmoskaluk
Mar 22, 2013
307
46
66
It sounds like your mini-retina does quite a bit better than my 'original' mini. It's certainly adequate for what I do, as I am normally at home and can connect it. But a 6 hr flight on which I did nothing other than read my book on Kindle will usually take it from 90 ish % to maybe 25 or 30 % ..... David
radtechy
Jul 20, 2011
505
41
Ouch!
Do you have Apple care that should warrant a replacement if the depletion is that severe
Sent from my iPhone 5S using Tapatalk
dmoskaluk
Mar 22, 2013
307
46
66
No I don't, and living in the Caribbean , support can be sketchy. It was purchased in San Francisco at the Apple Store on release day a year and a bit ago ( Nov 2012 ) The performance on the device itself is great, but battery wise I'd call yours 'better than average' and mine 'worse'. You battery stats look more like my wife' full size iPad (2) ..... I always figured that hers was simply better because of a bigger battery.... Now I wonder ! David
