Battery Indicator
mblahforu56432
Jul 6, 2009
33
One, is there a mod in which JUST the battery percentage is shown
Two, is there a mod where an iPhone user can disable the low battery warnings?
mblahforu56432
Jul 6, 2009
33
I have SBSettings from Cydia but I don't recall having an option to just show the battery percentage.
iphonewarrior
13,847
701
Swipe your status bar-
SBSettings will appear-
Tap 'More'-
Select Extra's and Options-
You will see a list of toggle's. Turn whatever you desire on. Press your home button, your phone will re-spring and there you go.. :eek:k:eek:k
mblahforu56432
Jul 6, 2009
33
when the battery indicator is selected the percentage number and the battery icon appear. i'm just looking for the battery percentage number only.
Saurabh
Sep 5, 2007
152
VA
BossPrefs allows you to do this too.
