battery level in % ?
Chris716
Nov 29, 2007
807
IL
Hi,
I was just wondering if there is any apps out there that can show the batterly level in %? Sometimes it's kind of hard to determine what the battery level is through the image . cause some how the battery looks like 10 or 15% but the warning signal pops out and say it's 20%. Thanks
Hondamaker
May 14, 2007
9,946
671
56
Fairborn, Ohio
Hi,
If you have jailbroken phone, use Customize and change the battery icon. There is one that shows battery life in %.
Youngbinks
Jun 4, 2007
7,617
31
Atlanta, Georgia
Yeah using customize to create your own battery icons would be the only way I am familiar with as well.
Chris716
Nov 29, 2007
807
IL
ah ok i never thought of that i will get on that right now thanks people
scandalex
Sep 16, 2007
771
there is an app I think its called Aqwoa battery.... Its in installer
Thanks OJ; I'm kinda scared of customize. Had a bad experience that forced me to restore. don't want to have to go through that again.
Edit- I cant find Aqwoa in Installer.
Spoolin414
Dec 6, 2007
93
Ft Lauderdale, FL
Aqwoa is not located in Installer, I have the full theme but I don't know what part of it your looking for.
I tried attaching the aqwoah zip but for some reason it wouldn't let me.
termleech
Sep 7, 2007
1,154
McPherson, KS
The newest Customize is a thousand times more stable and usable than it use to be. I wouldn't recommend it before, but after using 1.20 for quite some time I can say it has not had an ill effects and works pretty well.
ZipZap
Dec 15, 2007
529
I see nothing in appsnapp that changes the battery inidicator....what am I missing?
Will I only see it if I install the new installer beta?
6,682
49
did you completely miss my post about needing to add a source in installer ?
Chris716
Nov 29, 2007
807
IL
yah you have to add the sources or this stuff wont work because it wont be there lol...
ZipZap
Dec 15, 2007
529
I did not install the beta installer (if thats going to matter).
Customize (old/current) is in my list and I installed the current. I can see where you can change the icon but you have to supply a new one (which I don't have).
So I am missing something here I guess.
Any suggestions?
