Battery Life so far?
jnic429
Jan 17, 2009
86
I had 97% after sync. Played with everything on it for like 3-4 hours and battery went down to 24%. That seems a little fast don't you think? I've since charged it again to 100%. Been on it 20 mins and battery now at 97%. Problem?
Bennyboy
Jul 21, 2010
14,017
1,731
PA
Bennyboy yes :(
I have the same settings then my iP4s
I have tons of issues with that phone (I m a bid disappointed my iP4s had no issues worked flawless)
I may have to take it in ?
Well that's definitely not good at all. Play around with settings a bit. Turn LTE off if you don't use it. Check your notifications and let the battery all the way down and charge it overnight without using the phone. The usual stuff.
Bennyboy
Jul 21, 2010
14,017
1,731
PA
Speaking of battery life, where did location services go? I can't find it on settings.
Saverino
Jun 1, 2008
4,480
92
Burbank
The first day (yesterday), it was absolutely awful. I had to bring my charger with me everywhere. Today was much dramatically better, but still not up to par as my previous 4. I'm hoping a few more charge cycles later it'll be better.
MrMike6by9
Nov 16, 2008
1,482
119
72
Maryland, USA
I already went through the charge cycle and reset deal
Rechecked all settings
LTE should not matter I use WIFI at home
I am going through my 2nd cycle
Correct me if I'm wrong but if you don't turn off LTE, shouldn't your phone continue to search for the cell network in anticipation of your need to make and/or receive a regular phone call? Just askin'.
YMMV
jnic429
Jan 17, 2009
86
Should I trade in for a new one?
Also, I've noticed the phone is automatically changing my brightness setting to either full power or all the way down. iPhone 4 never did that. Something is pulling power from it in standby too. Even after I've closed the apps I was using is it location services?
one_crazy_dude
Sep 13, 2009
460
72
Toms River New Jersey
I don't know bout LTE but I noticed on other iPhones I had that mail kills battery fast. In settings>mail I turn all mail accounts that have push to off. Push uses a lot of battery. Then while in settings in fetch new data> advanced I select any mail that says push to fetch. This has helped many friends/family in the past with battery life so it's the first thing I did setting up my 5.
Hope this helps
rollinfromhell
Aug 1, 2007
1,232
44
Here my battery after the first charge last night wifi been on and stream radio few times out the day and texts surf the net Facebook watched 8-10 videos
Yeah could be a faulty phone. I remember posting a thread where my phone lasted 4 and a half -5 hours o fa little bit of everything people said it seemed fair. However, I restored it, and it still had the same issues with no apps and everything possible to conserve battery turned off. got the 5, it lasted 4 and a half hours tops the first day. i let it deplete all the way, and it lasted me 6 hours and 32 minutes on 1 percent. Not bad, compared to my 4S. Too bad my phone has a ding right out of the box, or and I may get a different phone.
