Battery Percentage Indicator
ashwini
Jun 2, 2009
334
India
www.ashwini.co.in
I couldnt find the option to turn on the battery percentage indicator in OS 3.0 beta 5. I directly upgraged from 2.2.1 to beta 5. didn't go from beta 1 > 2 > 3 > 4 > 5. Is that the reason? How do I get it?
5,578
http://en.wikipedia.org/wiki/Secure_Shell
Basically, it's a program for Mac or PC that allows you have root access to the phone so you can do a multitude of things such as changing themes. You have to be jailbroken to use it.
Chris Hyde
Oct 27, 2007
97
This doesn't work in 3.0b5. I just tried it and no battery meter.
styfle
Mar 31, 2008
3,381
I remember reading somewhere that the % indicator is actually in 3.0 now unlike 2.x.x but its not being used right now. Someone found the PNGs in the OS.
hitrho5
Jun 26, 2008
344
I have an easier solution. There is an app called Free Memory (1.4). It shows a list of running processes on the phone can free up to 20 MB of runtime memory. It also show battery charge level. It's in the app store, has been spproved by Apple and ony costs $1. No hacks required and works with firmware versions 2.0 or later. Hoped this helps :)
